Results 1 to 9 of 9
Thread: 86 fuel surge tank set up
    Member no fame's Avatar
    Harry
    Jp
    Wink 86 fuel surge tank set up
    yo
    im planning on setting up surge tank in 86 , running adm tank vl fuel pump and bt20v
    also 86 in stripped out and has rego so dont want anything to obvious in cabin
    just wondering what other people have done
    any help or pic would be much appreciated
    thanks.
    in tank pump
    Adan
    Oxley Park
    yeah, I run an intank walbro or something like that.
    Only seems to surge under quarter tank when throwing the car around alot.
    Member rianwest's Avatar
    May 2010
    Rian
    Taringa
    I run a VL in-tank lift pump to a 1L under-car surge tank, then to a VL external high pressure pump. There's not much room for surge tanks under the car so a small tank is necessary.
    Here's a pic of the setup out of the car:
    And this is a good write up on fitting an under-car surge tank to a KE70:
    Veteran slide86's Avatar
    Huw
    Hills
    Run an intake pump
    better yet, get a JDM tank and do it properly
    Aug 2010
    Geoff
    mt dandenong
    Ajps sells an undercar surge tank. My 86 has a modified tank.previous owner had the tank split opened and had it modified with some high pressure fuel setup and apparently a in tank surge tank.
    i need to open it up and have a look because it gets cornering surge when there is 10l or less in the tank =(
    Moderator Sam-Q's Avatar
    Endeavour Hills
    As above, the surge tank from AJPS is a work of art
    Veteran AJPS's Avatar
    Lonsdale
    thanks for the kind words sam, i am happy with the product
    to the OP, i have sold a fair few and they are definitely the way to go,
    an empty boot is good from you car and the police perspective and keeps the noise down
    pm me
    Harry
    Jp
    excellent , thanks guys
  1. in tank fuel pump with inbuilt surge tank
    By NIZLAH in forum Car Parts For Sale
    Last Post: 18th September 2012, 08:43 PM
  2. Replies: 3
    Last Post: 13th April 2012, 03:11 PM
  3. Fuel system, Surge tank, Fuel pump ect
    By stixy in forum Cars or Parts Wanted
    Last Post: 19th February 2011, 03:23 PM
  4. for sale , surge tank, aus fuel tank, hood linning + more
    By hillclimb86 in forum Car Parts For Sale
    Last Post: 20th June 2007, 12:20 PM
