Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: how hard would it be...
    Default how hard would it be...
    ...to make your own ncrca's? was looking at a thread on another forum and a dude with rt142 looks like (i could be wrong though) he has made his own rca's. if i went to a machining shop could they do it for me? if i took them the strut. anyone know of anywhere on the sunny coast.
    just curious.
    thanks
    Gone
    Joel
    Picton
    any reason u want NRCA's?
    more camber? go longer LCA or ADJ LCA
    that block looks rank as IMO.
    NRCA ads another shear point in the system.
    QUote - "apparently it makes the car feel a bit wak" aka strange handeling
    i was looking at using NRCA's just to get more clearance from the LCA in doing my brake conversion... but decided to to up another track.. much better
    i see u have AJPS as your Sig... ask Lawson y he doesnt sell them anymore
    Alex
    Wagga Wagga
    I can see it being easier and cheaper to just buy some.
    Alex's 4AGTE KE70
    Or so was thought...
    i just put corona lcas in and i just wanted a little bit more camber/track. its on a ke70 btw.
    ill got hit up lawson
    Dave
    i say go for it, have a go, at least get some quotes to compare it with.
    like that guy has made its only a piece of alloy with 4 holts drilled in it.
    your best would be to draw it all up nice and proper in auto cad. with exactly what you want. though it might cost you a fair bit since you are only getting one thing made. but its a very simple item so you never know might be cheap.
    what are they worth to buy anyway? like $200?
    Veteran Konakid's Avatar
    Henry
    Eastern
    Ahh its not that simple, you need to get steel locators made up, correct tensile, length, and thread bolts, springs washers, etc.
    RCA's are a bandaid solution.
    The easiest way to a wider track is wider wheels.
    What wheels are you running?
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    i thought the whole main point of RCA was to correct the low roll centre point to increase handling etc?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    NRCA's are crap, they stuff up your scrub radius. Just run lower ocntrol arms and camber tops wound out for wider track
    Henry
    Eastern
    FAIL
    That can fit in with that adjustable steel plate and bolt lca pic.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Thats soo nasty...
    Just Either buy some or run longer LCA's...
    Much better than haveing your wheels floping around by itself when something breaks..
  1. Why is my car pulling to the right hard?
    Last Post: 3rd December 2009, 09:33 PM
  2. Clutch hard line
    By Dom86 in forum Cars or Parts Wanted
    Last Post: 9th July 2009, 08:09 PM
  3. How hard is it to get hold of parts...
    By waverley in forum General Topics (No Technical Questions)
    Last Post: 15th July 2006, 01:15 PM
