Pretty much all motors are rough when cold. Hook cold start back up
Hi can any1 help with cold start issue in sa. The motor abit rough on start up for around two minutes then once warmed up then runs fine. The cold start is disconnected. Can any one help?
Is there any way to bypass the cold start? Brought the motor with the cold start blocked off.
If it is blocked off, its bypassed.
I know my smallport runs rough without the coldstart and idle up disconnected.
I keep them connected and the engine starts and runs fine.
