Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Australias highest KMS on a Toyota 86 and issues experienced..
  1. #21
    Site Supporter
    Nov 2012
    Tony
    I've found recently my rear parcel shelf has started to rattle and somewhere up under the dash. I have done 14,000kms on mine.
  2. #22
    Veteran Nikkojoe's Avatar
    Tom
    My high mount (3rd brake light) started rattling on a rough road. Had to add some thin foam tape (left over from trd kit) between a joint in the brake light assembly. Also the keyless entry receiver on the parcel shelf rattles on most cars but I sorted mine out before it started.
    Under dash ones are probably parts of the wiring harness rattling against the plastic (most of the time ones near the center stack/radio).
  3. #23
    Site Supporter
    Nov 2012
    Tony
    The rattle under my dash is coming from near the stereo, I am tempted to pull it apart but knowing me I will probably break something when pulling it apart.
    I'll look at the central locking unit. Are rattles something that are covered under the new car warranty?
    Other than that I've had no other problems
  4. #24
    Tom
    There should be a service bulletin for the central locking receiver rattle but the other one in the radio area would require trial and error via dealer.
    They are pretty simple to remove, all the trims around the head unit are just clipped on. This guide here (scroll down until you get to the head unit trim removal) should make things easy. Always disconnect the battery
    Rear deck if you are keen
  5. #25
    Site Supporter
    Nov 2012
    Tony
    This morning on the way to work , the car started to run on 3 cylinders. Took it into the Toyota dealership at work and they replaced a coil pack.
    Just got a call a minute ago, and they have replaced a coil pack which is covered under warranty
  6. #26
    Site Supporter
    Nov 2012
    Tony
    Noticed today that i'm dripping oil out of the cam plate onto the exhaust. It is worse after some spirited driving.
    FT86club seams to recommend getting to fix it.
  7. #27
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Cleaning and re-sealing wouldn't do the same job?
  1. NSW : FS Toyota Crown 1984, Low KMs, 12 months rego
    By MoNsTaR in forum Cars for Sale (Toyota Only)
    Last Post: 13th May 2013, 08:32 PM
  2. AE101 '92 Toyota Levin - LOW LOW kms - Clean - 5sp - VANCOUVER
    By lchazl in forum Cars for Sale (Toyota Only)
    Last Post: 30th July 2009, 08:23 AM
  3. australias best 86
    By Touge205 in forum Offtopic Discussions
    Last Post: 16th March 2007, 12:06 AM
