Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 35
Thread: Rust Removal Tips n Tricks
  1. #21
    I find using an oxy so much easier than mig. Just prob what I have used the most. My mig on the lowest setting still burns holes in the job easily. It doesn't have a pulse option which sucks.
    I have about 200 odd pics from repairs I've done recently which ill use for new threads depending on what you want you need to do.
  2. #22
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    No he cuts old one out. So first he cuts out a replacement but bigger then the rust then uses that as a template to cut out the rust then removes it all and welds in new bit
  3. #23
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    So he then welds in in flush, if that's the case sounds good, what welding technique does he use & any finished welding before painted photos would be good / interesting to see ..
  4. #24
    Mar 2013
    Mirko
    Full old school not lead but cant remember whats its called. Ill take some pics put its good work l can say that
  5. #25
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    For body panels, if u have access to an oxy welder and the skills to do it, then that is the way to go. Much neater welds. Can file finish if ur fussy. Much easier to hammer and dolly and file. For parts that are not visual or structural components. Then mig welding is best. Doesnt need to be as neat cause its hidden, more strength for structural areas, a lot less fiddley and quicker.
  6. #26
    Senior Member K1W1 Simo's Avatar
    Dec 2012
    Simon
    Mt Coolum
    When I was in the 'resto' business, I spent 4 months on an Alfa Junior body- hand making panels, butt welding them in and hammer and filing the whole car to a smooth paintable surface. That would of cost the owner $20,000 + in body work alone. The 86 and the Alfa both have really thin steel panels, very hard to work with.
  7. #27
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    Is a layer of bog over new welds essential for filling nooks and crannys or is it only cosmetic? I don't really want to use it since my welded bits are all hidden by bumpers and cowls
  8. #28
    Mar 2010
    Brett
    Crestmead
    Bog isnt necessary. If the parts are hidden then I would bother. But for the outside body panels, if u want it to look smooth and not spend hours file finishing then bog is ur best friend.
  9. #29
    Mar 2014
    Kenmore
    For removing the rust there is need of organic polymer, which provides a primer layer on the surface and remove the rust completely.
  10. #30
    Junior Member roughworld's Avatar
    D
    Vic
    Springvale
    Ive just noticed this thread, don't know how I missed it haha.. Ive been working in restoration for the last 6 years, Its always been a passion of mine, and to save killing it I got out of smash repair asap
    I personally wouldn't touch corolla outer skins with an oxy, but I'm interested to see some pics of those who have
    Couple tips I've got for mig welding rust repairs, always try and make your patch with rounded edges instead of just a square with sharp edges.. It distributes the heat a lot better and you'll have less chance of warping. And take your time fitting the patch, ultimately you want your patch slightly undersized like 1-2mm, it gives it room to stretch with the heat. If u don't leave room and the patch is too snug, you'll notice your patch will raise up because it its got nowhere to go.
    Its always good to have a wet rag handy too, for an area like a roof, or bonnet, keep the area near your welds cool for less chance of warping. Id be happy to help anyone in s.e subs if beers supplied
  1. Paint Preperation Tips n Tricks
    By Matt in forum Restoration / Body Work
    Last Post: 6th June 2013, 07:40 AM
  2. How to weld tips n Tricks
    Last Post: 21st May 2013, 12:46 AM
  3. Brake Installs – Tips, tricks and products
    Last Post: 16th November 2012, 03:54 PM
  4. Broken wheel nut (Need tips on removal)
    By GOT-20V in forum Technical - Rims & Tyres
    Last Post: 15th October 2011, 02:13 AM
  5. Rust removal
    By lawrencelalot in forum Adelaide & SA Events and Discussion
    Last Post: 16th July 2010, 09:01 PM
