Forum Special Offer
For all of this month mention that you found us on the forum and we’ll give you a 10% discount on all your purchases from Pro Speed Racing (ex. coilovers and turbos)
To visit our website go to:
Or to send us an email
About Us
We sell Australia’s leading range of parts for Japanese performance cars.
We sell thousands of different parts for all Japanese performance cars. Based in Sydney, we distribute all though out Australia.
Our Parts
We’ve got exhaust systems, engine parts, fuel systems, suspension and much more.
Here’s what we’ve got for the Blouch Rbk Dominator 1.5Xtr
Specs
Garrett Ball bearing CHRA
56.5mm Turbine Wheel
71mm XT Compressor wheel
49lbs per min
8cm or 10cm Exhaust housing available
The Blouch Dominator RBK1.5XT-R is a little tweak to our already popular Dom 2.5XT-R. (As I have mentioned before, we are never satisfied with status quo and we are always tweaking something). Originally designed for our 2.0L customers in the UK, the Dom 1.5XT-R uses the Garrett GT 56.5mm turbine instead of the full 60mm turbine of the Dom 2.5XT-R. The end result is a slightly quicker spooling turbo while trading off some high RPM horsepower capability.
Beyond the turbine wheel, the Dom 1.5XT-R consists of the same cutting edge turbo technology that you have come to expect from Blouch Performance Turbo: Blouch billet fully-machined closed die forged 49 lb/min XT-R compressor wheel with state-of-the-art aero, our own custom compressor housing machined in-house and designed for improved fitment, Garrett GT ball bearing center housing and Blouch custom 10cm2 turbine housing with adjustable upgrade actuator.
No boost creep worries here with the smaller turbine - our turbine housing and wastewater actuator are designed to work together to ease your tuner's job and provide the flattest possible boost curve. All of this complete with turbo mounting gaskets, oil feed restrictor, braided stainless steel turbo oil feed line, oil drain tube, coolant pipes, banjo bolts and copper washers. Only at BPT and PSR!
Power Range: 240-280kw@wheels with supporting mods
Cars Suit: All Subarus (08-12 WRX require TMIC or FMIC)
Contact
0418 436 861
To email us
Unit 9/218 Wisemans Ferry Road,
Somersby, NSW 2250
