Ebay....trick is knowing what fits!
Landcruiser and Celica's use the same part......they were cheaper than celica ones too
Were u get the extractors. They look mint
43ger
Performance
SINCE 2008
Oh nice. I might look in to it
some various shots throughout the conversion....I ended up having to pull the head off again,drilling out that one head bolt I mentioned and installing a hallicoil before refitting....wasn't too hard tho!
I've also got a bad habit of snapping bolts......had to redrill and tap 2 holes in the back of the head for that plate/water gallery thing pictured.
Don't mind the piece of garden hose.....I ran out of money this week and forgot to buy hoses,hahaha!
She runs great tho now,easily on par with other 22re's ivé had if not better.....I did have an issue with a loud tapping noise in the front of the engine at first,I thought I'd damaged the chain guides but everything was intact......Ended up being the fan,I'd done it up finger tight and forgot to go back to it after the belt was adjusted.
rwc and rego now and then It's time to get low!
then once the rego's out of the way I can start saving for some wheels......looking at something less common than the norm...I.e... No meshies or longchamps etc....haha,maybe some Hayashi streets,or star sharks or something like that?
43ger
Performance
SINCE 2008
I also need an RA65 radiator......the corona unit's mount up different on the Rad support and cable ties wont pass rwc
43ger
Performance
SINCE 2008
43ger
Performance
SINCE 2008
So is it a 22 or 21 in there im confused
U swap the cam cover over
21.. It's an Ra60. And carbied.
Cut the springs. Lock the diff. Do the dori.
