Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: KE70 - Volvo B230FK
    Nov 2012
    Gretar
    Reykjavik
    brh
    Iceland
    Default KE70 - Volvo B230FK
    This is my 1980 corolla wich I have owned for 3 years now but first started to work on about 2 months ago.
    still a working project but will hopefully finish the mechanical stuff in 2-3 weeks
    I'm putting in a Volvo B230FK engine and m90 transmission.
    With 700cc injectors and 16t volvo turbo and about 18-20psi it will be around 250+ hp
    All controlled with MS3
    I used s13 running gear in the front but with custom made lower control arms.
    s13 coilovers front and rear
    I put a 1980 hilux rear axle and vw rear brake calipers and hilux front brake discs,machined to fit
    some pics of the process
    last year I had already fitted a ca18det engine and transmission, but when I took the engine apart I realized that the engine was blown.
    had to cut a little bit into the firewall
    not much room in there
    test fitting the engine
    finishing up the x member
    Lca´s in making
    AE86 tophats and a brake master from a MMC Pajero
    and ofcourse hydrolic handbrake
    refurbished s13 calipers
    MMC evo 8 seats
    radiator from a Ford transit diesel
    16t turbo original from a volvo 850 T5
    test fitting after making the lower brackets
    and with tires
    gas tank from a wrangler made to fit
    everything ready, just waiting for the coilovers to arrive so I can finish the rear axle
    in the meanwhile MS3 was connected up and it fired up and idled nicely in first try
    Coilovers arrived and installed in the front
    Nov 2012
    Gretar
    Reykjavik
    brh
    Iceland
    making room for the rear shocks
    a pump bracket from a Subaru RS made to fit in the wrangler tank with a 255 walbro
    steering rack in place, had to modify the oil pan a bit to make this work
    Only lost 1L of oil capacity, which was added in the front
    After finishing the oil pan the x-member was finished up as well
    No room on the right side for the exhaust so I had to cut it up a bit.. again
    Decided to make a side exit for the exhaust
    All finished up
    doing the intercooler piping
    3,5" exhaust vs. 3" impreza downpipe
    Engine out to finish up the bodywork in the transmission tunnel
    The oil pan nice and shiny
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Great to see differant combos going into these cars
    May 2013
    South Australia
    seems like a lot of work for a little gain
    do you know the weights etc of the motor gearbox combo?
    great to see something different
    Veteran johl's Avatar
    Johl
    thats awesome. are you doing all the work yourself? is that the 5 cylinder volvo motor?
    JoJo
    ACT
    Tuggeranong
    Little Gain?
    Having a one of a kind KE70 is hardly a little gain....
    And, he obviously enjoys doing the work, lets him go nuts!
    Sep 2012
    Jacob
    Joondalup
    This is insane... but such awesome work so far!
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    This built is very different!! I also think it is awsome!!!
    Keep the updates rolling on
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    That's awesome!
    quit hatin get bakin!
    Member luke04's Avatar
    Jul 2011
    Luke
    RADELAIDE
    wicked rig man! so good to see something different than whats going on in aus!
  1. VOLVO 242GT
    By hall sales in forum Cars for Sale (Not Toyotas)
    Last Post: 5th March 2012, 11:27 PM
  2. Volvo powered KE70, whatup
    By Armiee in forum Toyotas in the Media
    Last Post: 21st January 2011, 11:00 AM
  3. my new volvo
    By Dazzla86 in forum Youtube Chan
    Last Post: 10th March 2010, 05:12 PM
