Results 1 to 2 of 2
Thread: Lappy's 3RZ bolt in conversion kit!
    Senior Member lappy's Avatar
    Brenton
    Eaton
    Default Lappy's 3RZ bolt in conversion kit!
    As some of you may have seen in my build thread, I've slowly been replacing every conversion part so I'll end up with this whole kit for sale.
    I made 124hp and 201nm with this set up and It happily fried 3rd and 4th gear all day long.
    All you need to do is buy an engine and box with ecu and wiring, get a tailshaft made, the tunnel will need some love tapping/massaging to fit as it sits quite far back, cut the shifter hole a bit, for better shifter position I bent the shifter backwards and a bonnet scoop or space the crossmembers down(may not work with engine clearance in some areas). I will supply a wiring diagram aswell.
    Includes:
    Engine crossmember
    Gearbox crossmember
    Alloy sump
    Oil pick up
    Extractors 1 3/4" primaries all within 15mm in length
    Exaust 2.5" dumps before diff
    Intake pipe
    AFM set up
    Pod filter to suit
    Intake pipe heat shield
    Top radiator hose
    Modified fuel inlet
    Attachment 27306
    For any more pics/info check my build thread:
    Here is what I managed to do with this set up:
    Chasing $2000 If you had to pay for an exhaust shop to make the extractors to this precision and quality alone would be this much if not more
    Located in WA, I'm willing to ship Australia wide but the exhaust might have to be cut in half for cheaper postage
    Brenton
    Eaton
    price drop $1700
  1. 3RZ Ksev
    By lappy in forum KE70 / AE71 Owners Forums
    Last Post: 26th May 2014, 06:37 AM
  2. Lappy's AE71 daily/drifter
    Last Post: 19th September 2012, 04:44 AM
  3. Bolt on CA18DET Conversion kit for AE86/AE71
    By bui_ke70 in forum Car Parts For Sale
    Last Post: 8th December 2011, 05:07 PM
  4. 3RZ-FE into KE70 for Drift?????????
    By Plelz in forum Technical - Questions
    Last Post: 16th November 2010, 05:10 PM
  5. Bolt in w57 conversion
    By biggo in forum Car Parts For Sale
    Last Post: 28th December 2009, 06:42 PM
