Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 21 to 30 of 76
Thread: Sunny Ute
  1. #21
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    Underside painted, diff is 90% assembled and back in, Small odds and ends have been finished up and HOPEFULLY I'll have the bay/cabin sprayed this weekend ready for shit to be installed again. I'm sick of having parts everywhere!
  2. #22
    Clint
    Sutherland Shire
    New Panels were bought for this, so I got the front end assembled to check where the new beaver had to be welded on.
    I couldn't help myself but test fit my front lip. It's a Diahatsu Handy front bar. It still needs final trimming once I have the lights etc in but it's the rough idea I wanted. I've kept all the cut off bits though because I might use the fins in the bar still. Not sure yet.
    The interior was cleaned and then seam sealed
    While this was drying I decided to coat the underside
    The next day I primed the interior
    Diff was sorted, sealed the centre properly and tightened it all in, as well as the axles with the caliper brackets etc
    Decided to seal all the seams in the bay too, so they were masked up, sealed and smoothed over to get rid of the nasty seam lines and fill in any gaps between seams to prevent water getting in there
    Engine dropped out with a final coat of primer
    Had to press the extractors a bit, they are AE86 items and were hitting the chassis rail. Pressed them down about 100mm to try and bend them in 20mm, left them in there overnight and then they fitted perfectly.
    Sprayed the bay in the colour that I'll be using for the whole car. Got the engine back in along with all the other odds and bobs for the bay. Still not happy about that carb manifold so I've got a flange ordered to make my own one the way I want it done!
    RX2 rad installed, washer bottle, rad overflow, AE86 coilovers, Datsun 1200 camber tops....
    Speaking of AE86 front struts in these, this is the lock you get. Well this is with my setup anyway. AE86 struts, AE86 power steering arms, AE86 manual steering rack. Clears everything by ~10mm with 13x8 -11 offset. Sold these wheels though due to wanting 8.5's all round.
    I've moved all the relays etc out of the engine bay to hide them under the dash in the cabin, currently dealing with wires and shit and trying to work out whats going where. I hate wiring and I haven't even started doing the dash, engine or new KE70 steering column combination switches!
    All wiring and bonnet latch cable was moved from going through the engine bay to the wheel arch area of the car and is coming into the bay under the relocated battery tray and will be run through wiring tube to try and protect it from rocks etc.
    Anyway, this is where I'm up to. The list keeps growing! Stay tuned.
  3. #23
    Veteran drift kid's Avatar
    Glossodia
    Holy jeebus, this is amazing, that front lip is sick too man, great work, keep it up
  4. #24
    Ridgehaven
    ^ yep
    this is very impressive
  5. #25
    Clint
    Sutherland Shire
    Cheers guys!
    There'll be more work done over the weekend, hopefully get the fuel/brake lines back in and get the rear brakes all set up!
  6. #26
    ACT
    Compton
    Gonna be awesome
  7. #27
    Mar 2011
    Daniel
    Daveron Park
    Nice work mate! Makes me wanna get stuck back into my 4AGE Sunnyt truck!
  8. #28
    Clint
    Sutherland Shire
    So I sold my SSR starsharks that I had for this due to the 9's being too wide for the back. Want 8.5's all round, not really a fan of staggered wheel sizes either.
    Bought a set of SSR superstars from Japan. 13x6.5 +13 offset so I'm going to get them re barrelled to 8.5's. Got an absolute bargain too, $200 for a full set! Stoked!
  9. #29
    Clint
    Sutherland Shire
    Bit of an update..
    Decided it was out with the stock tailgate latches. Didn't want a 70's door handle on the back of my car so the mounts were cut out
    and they were welded up all flat to allow for the new latches
    Got the carbon fibre Aerocatch latches and then marked them out/mounted them
    All finished and mounted to the car
    The most fab work was done on the inside of the tailgate that you don't even see, I'll have a photo of that in a bit when I remember to do it. I'm stoked with how it turned out, I wasn't really feeling confident on how it was going to look but it looks real clean now which is what I was after!
    Right now I'm fabbing up the new intake manifold, then the carbs will be staying on the engine for good!
  10. #30
    Senior Member K1W1 Simo's Avatar
    Dec 2012
    Simon
    Mt Coolum
    Some Dato ute styling here
  1. Sunny Truck
    By Undeez in forum Dirty Dattos
    Last Post: 1st December 2014, 10:26 PM
  2. Sunny coast thread
    By biggo in forum Brisbane & QLD Events and Discussion
    Last Post: 24th November 2011, 11:03 AM
  3. nissan sunny ute
    By scuba86 in forum Cars for Sale (Not Toyotas)
    Last Post: 8th June 2009, 11:09 PM
  4. sunny coast?
    By scott_22 in forum Brisbane & QLD Events and Discussion
    Last Post: 20th March 2009, 11:45 PM
