Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: 4age 16V- Genuine and upgrade parts
  1. #11
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Now in stock:
    bigport +0.5mm rings
    cam seals
    crank pulleys
    thrust bearings
    small end bearings
    smallport gasket and seal kit
    I am trying to organise to get the following:
    TPS
    Bigport gasket sets
    cam cover seals
    head stud seals
    16V injector O-rings
    genuine oil filters
  2. #12
    Endeavour Hills
    Now available 16V distributor blanking covers:
    Stop the need for 4AGZE crank angle sensors and even be used to replace the OEM ZE cover as a dress up item. It's a universal design so it should suit all three types of 16V distributor I have found so far and even 3SG engines.
    Price $90 + post inc bolts
  3. #13
    Member Jake70's Avatar
    Sep 2013
    Jake
    Forster
    hi mate are you able to order 4agze conrods and rebuild kit?
    thanks, Jake
  4. #14
    Endeavour Hills
    Jake I looked up the price of some rods a little while ago and it was the same as aftermarket. So that considered and the fact of how much they weigh that I don't suggest it.
    I have little end and crank thrust bearings in stock, big ends and crank shells can be ordered in as needed but ACL performance shells are pretty good.
    Getting a small port gasket set is no problem, haven't checked for bigport ZE set yet.
    Water pumps and belt kits are easy.
    For the oil pump pending what you have now I have an off the shelf upgrade from Toyota for $150 new and genuine.
  5. #15
    Apr 2010
    LK
    Hi Sam,
    Do you have a crankshaft for 4age 16V?If so, how much?
    Leo
  6. #16
    Endeavour Hills
    I have a single one. Suits smallport to blacktop.
    New in the box for $700
  7. #17
    Senior Member K1W1 Simo's Avatar
    Dec 2012
    Simon
    Mt Coolum
    Hi Sam,
    Do you know where I can get my hands on a new shaft and drive gear for my distributor?
    Simon
  8. #18
    Endeavour Hills
    The shaft no, as they are only listed as a complete unit but the drive gear and pin yes, I could probably get one for $40. Send me a PM if interested
  1. solid lifter upgrade 16v 4age.
    By MoNsTaR in forum Technical - Questions
    Last Post: 19th February 2014, 07:41 PM
  2. 3sge BEAMS & 3sgte- Genuine and upgrade parts
    By Sam-Q in forum SQ Engineering
    Last Post: 23rd August 2013, 09:38 PM
  3. Replies: 2
    Last Post: 13th February 2012, 10:18 PM
  4. 4AGE 16v GENUINE CAST EXHUAST MANIFOLD
    By AIROCOBRA in forum Car Parts For Sale
    Last Post: 13th December 2011, 04:14 PM
  5. 4AGE 16V injector upgrade
    By aus_86 in forum Technical - Questions
    Last Post: 5th April 2011, 12:14 AM
