Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: White Dog - Stock 4k DX Sedan - AKA Goodie Fu@&n 2 Shoe's
    Mar 2011
    Ali
    Default White Dog - Stock 4k DX Sedan - AKA Goodie Fu@&n 2 Shoe's
    Picked up this one a few weeks ago off a mate who owned it for last ~5 years and let it go.
    Body was bit rough, so set about doing rust repairs.
    BODY/EXTERIOR:
    Quad light conversion
    MK1 Golf 2 piece lower lip
    Rear window venetian blind
    Towbar installed (for rear extra chassis rigidity)
    Vinyl black "corolla" pin-striping
    *Paint is a bit rough, but presents ok.
    INTERIOR:
    Factory Tacho Dash (modified to work with current coil set up)
    Blue material, well maintained.
    Twin Cam Steering Wheel
    Recaro driver seat - Retrimmed, with all new genuine Recaro foams installed on factory Recaro/Toyota Runner!
    *Has speakers installed into front doors on beige mounting base, looks a bit out of place?
    CD/USB Player
    ENGINE:
    St 20V in RWD format
    Open quads with ITG filter socks and internal springs
    Sard adjustable FPR
    T2 Alloy lightweight crank pulley and water pump under drive pulley
    Laser cut alloy "Idle speed control valve deletion plate" installed to top of ITB.
    All ITB hoses replaced with blue silicon with use of a vacuum block - cleaned up the factory rats nest.
    Dizzy blank plate
    Thermostat bypass plate
    Rear waterpipe block
    RWD 4A engine mounts
    Wrapped Stainless steel 4-1 header
    Microtech ECU and Dash unit with wiring full loom to suit St20V
    Cusco Strut brace
    AE71 Alloy radiator mounted laser cut brackets with rubber mounting grommets.
    16" Toyota Denso radiator mounted to rad on stainless steel brackets.
    Internal regulator alternator wiring mod
    Speedflow fittings used where possible
    Brand new oil filter and oil installed.
    DRIVETRAIN:
    Clutch master cyl - fire wall mod / hole
    AE71 Pedal Box with brand new T18 master cylinder
    Blue braided clutch line - master to slave
    Brand new slave cyl
    W55 with A-Z customs T50 Bell adapter – shifter hole requires no cutting at all on manual or auto xE7x, perfect position
    JDM T50 bell (Clutch fork on Driver side)
    ST Flywheel (212mm)
    Exceddy 4 puck solid brass button clutch
    Tailshaft to suit W55 to ke70 Corolla BW stock diff
    Stock Open BW Diff
    *This is a over 2K worth of set up, unlike your T50, you wont break this gearbox ever..... unless your doing something really wrong! and perfect if you want to go SC or Turbo.
    *Have S1 TE72 T series drum to drum with stock 2 piece tailshaft
    SUSPENSION:
    Stock suspension and ride height
    New AJPS motorsport Tie rods
    New AJPS rack spacer
    New AJPS poly rack bushes
    Sigma Control arms with modded Nolathane bushes to suit AE71 Xmember
    Brand new ball joints installed.
    *I have Kings lowered front coils springs and rear Kings chopped falcon springs, but will attract the wrong kind attention.
    WHEELS:
    5 x CSX/DXX Alloy's - BF Goodrich tyres with good tread.
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    Doesn't look to bad at all.
    quit hatin get bakin!
    Senior Member Mika's Avatar
    Jun 2011
    Daniel
    clean dude!
    Mar 2011
    Ali
    Rego'd and on the street.
    Never driven 4K before, best learn to enjoy the ride, coz White Dxx ain't going nowhere real fast!
    Its so slow......Nah serious it painfully slow.
    Got some time off over Christmas, 20V Engine, WSeries box, ECU make it happen.
    Jun 2011
    Daniel
    Keen to see this progress dude!
    Mar 2011
    Ali
    Itching to go
    Mar 2011
    Ali
    Mar 2011
    Ali
    Updates:
    4K and K50 out
    4A Engine crossmember in
    Need to source"quality" spigot bearing for W Series
    OK, so I called every Repco, Walkers Auto, Aussie Auto, Autobarn in area (no Bursons near me) as NPC and Direct are shut until monday.
    None stock Narchi or NSK pilot bearing 6001 2RS WTF, all have same Chinese poo.
    While I was sulking I was cleaning up to new engine and noticed that the timing belt tensioner spring was just dangling loose.
    So I stopped in my tracks, got a pair of needle nose pliers and went about re attaching it to shaft with groove poking out thinking problem solved.
    But when I did this, its is still loose
    Spring does not sit in groove and locate with tension.
    Is there a circlip that goes on the groove to prevent spring coming off?
    or do I replace spring with new one that fits with tension
    Or manipulate the existing one to take up slack - as it will just fly off again as is?
    I probably should search tech questions before I ask here....hmmm
    Mar 2011
    Ali
    I'm lucky it has not caused any damage as I drove donor car before parting out...
    Read a few differing opinions, some say keep, some say ditch.
    Ditch for now, timing cover stays off, new one soon.
    Senior Member pt_y2k's Avatar
    Paul
    Is the spring not to just keep tension on the pulley for when fitting the belt? As in it dosent determine the tightness of the belt therefore ditch it...
  1. Vic: White ae71 manual sedan
    By Hokey in forum Cars for Sale (Toyota Only)
    Last Post: 28th April 2013, 06:22 PM
  2. S.A. WTB = AE92 Sedan Parts (White Prefferably)
    By PINK_KE30 in forum Cars or Parts Wanted
    Last Post: 27th February 2011, 10:06 AM
  3. white ae71 sedan auto melbourne
    By djhatzigiannis in forum Cars for Sale (Toyota Only)
    Last Post: 10th September 2010, 10:47 AM
  4. VIC: White ae71 or ke70, I will trade my TE71 sedan for one!
    By Sprinter86 in forum Cars or Parts Wanted
    Last Post: 16th April 2010, 03:30 PM
  5. [VIC] AE71 manual sedan, white, 1200 ono Melb
    By *E7* in forum Cars for Sale (Toyota Only)
    Last Post: 2nd June 2009, 09:06 PM
