Results 1 to 6 of 6
Thread: MkIII Offset?
    Senior Member Zane k's Avatar
    Aug 2011
    Zane
    Gold Coast
    Default MkIII Offset?
    Okay so I've got a pair of mk3's and they are 14x6.5 +19 (B Type). I'm getting them widened to 9'. Could anyone on here be able to tell me they rough offset they will end up being? Thanks.
    TailorMade☆DC
    20v 4AG Corolla:
    Veteran johl's Avatar
    Johl
    just measure from where the wheel face mounts to the hub, from that surface to the inside lip ( the side of the wheel closest to the suspension) for this example sake lets say you get 3 inches. you will be widening them to 9 inches wide, therefor adding 6 inches past the hub. zero offset would have 4.5 inches each side of the hub, but we started with a measurement of 3 inches of back space so find out the difference between zero and where the hub actually sits and that is your offset. in this case it will be 1.5inches or what ever that is in mm.
    this took a little while to type and surely you could have just googled it or thought about it for 3 to 7 minutes and came up with a solution
    Aug 2010
    Geoff
    mt dandenong
    Neg 15 roughly at a guess. That's if your getting the outers made.
    If your doing both inners and outers then offset will be whatever you want obviously
    Aug 2011
    Zane
    Gold Coast
    Thanks geoff that's what I was after.
    TailorMade☆DC
    20v 4AG Corolla:
    Aug 2010
    Geoff
    mt dandenong
    You can work it out quite accurately if you plot it out on paper. Mark out 6.5", half that then plus 19. Mark 9" wide over that adding the extra width to the outside then half that and measure back from the center to the hub mount.
    Oct 2011
    luke
    Vic
    city
    Where did you get your wheels done? Got any pics?
  1. QLD 15x8 SSR MKIII
    By racsov in forum Car Parts For Sale
    Last Post: 2nd February 2012, 07:25 PM
  2. SSR MkIII's - 15x8-7 (Pair)
    By KE_OBCT in forum Car Parts For Sale
    Last Post: 17th May 2010, 04:49 PM
  3. SSR mkIII's
    By drft86 in forum Cars or Parts Wanted
    Last Post: 3rd November 2009, 07:59 PM
  4. pair of SSR MKIII wheels
    By chapl in forum Car Parts For Sale
    Last Post: 21st December 2007, 02:21 PM
  5. SSR MKII and MKIII...
    By ArJay in forum Technical - Questions
    Last Post: 8th April 2007, 04:05 PM
