I have std ae101 at home frak. Shoot me a pm, I am north east suburbs
Messing around today at work and decided to flow a 50mm orifice plate against an Imec AE111 ram tube.
The orifice plate flowed 335cfm @ 28inches of water
The Imec ramtube flowed 472cfm @ 28inches of water.
If I find a standard AE111 ramtube I'll give that a go on the flow bench as well.
Big up's for the North East Massiv'
NSATB - New Skids Around The Block
And can access a t3 too if you like
Keen to see some figures of stock have we been mislead all this time haha
Me too.
Thought I would give a bit of an update on this seeing me and Jamie have been quite a lot of trial and error on the flow bench for my product development.
These where all tested at the same time at 28 inches of water. All the "SQ" ones where 3D printed prototypes that had been smoothed out before being flowed. None of the final versions have been flowed yet, it's quite likely that they will flow a tiny bit less due to the polished surface.
More about those ones
OEM BT: 320
OEM ST: 342
HRC: 445
IMEC: 483
Early SQ Blacktop: 484
Revised SQ Blacktop: 496
A few things surprised me about these results, such as how good IMEC are for such a simple design, how bad OEM is but most of all that silvertop outflowed black, to my eyes the silvertop factory trumpets look downright terrible with the transition into the throttle.
I really want to see a back to back run of OEM vs aftermaket on the dyno now.
