i would be concerned if you gave 3.... :/
I give this two thumbs up
I'd prefer 3..
Painted up the bonnet latch and latch support and bolted them in aswell as the drivers side bonet hinge and a blanking plate on the firewall as well as finishing up the lines on the trans oil cooler and bolting that into place, not much else happened as I was also working on the 86
I am officially terrified
Yep.... I dont touch wiring for that very reason
Makes me just want to give it to a wiring guy and empty my wallet. Also fixed the last little bit of rust under the windscreen on the passenger side and fish oiled in the wiper plenum, now to flick a little paint around there and get the dash/wiring sorted so the new windscreen can go in. God I wana drive this damn thing
Why did you yank all the wiring out like that?
That is the two looms sat in the car to go behind the dash
Moar progress! Got 99% of the loom plugged in, need to figure out where the shit the fuel pump wiring comes from :/ I also installed the new throttle cable that I had made, painted the washer jets and installed them, rivetted the vin plates back onto the firewall and 99% finished the fuse box side of things. I also installed the heater box and tucked a little bit of the loom under the dash. And last but not least, I put the brake lines back in, they all bolted straight up bar the little front one! Which I made up, super productive day!![]()
