Results 1 to 4 of 4
Thread: Cleaning ISCV on 20v 4age
    Apr 2013
    Joshua
    New South Wales
    Eaglevale
    Default Cleaning ISCV on 20v 4age
    HI i was wondering if anyone know hows to take apart the iscv on a 20v to clean it i have it off but i am having trouble trying to take it apart to clean it any help or a DIY explanation would be appreciated?
    Thanks Josh
    May 2012
    ACT
    belconnen
    I would just spray each hole with a heap of TB cleaner, and scrub what I can get to with a small toothbrush or something. I wouldn't bother taking it apart, as I don't think its really designed to be a serviceable part.
    West
    Give it to ya mum.
    Dec 2013
    Jon
    Wellington
    City
    New Zealand
    This ^^^... the screws on the cover at the bottom should be sealed with a dab
    of paint to indicate that they are factory set. There is also a smear of silicone under
    the cover to keep it leak tight. Nothing bad happens if you take it apart, but you
    should try and put it back exactly as it was, as the bi-metallic spring is there to do
    the right thing if your ISCV loses power.
    Cheers... jondee86
  1. 4age 20v iscv
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 10th April 2013, 10:43 AM
  2. 20V ISCV; S/T or B/T
    By GeeEss in forum Cars or Parts Wanted
    Last Post: 23rd September 2011, 12:15 AM
  3. badly need iac or iscv for 4age 20v
    By ae8620v in forum Cars or Parts Wanted
    Last Post: 24th August 2011, 04:39 PM
