Results 1 to 9 of 9
Thread: ae86 rust removal
    Dec 2013
    Doug
    Auckland
    Auckland
    New Zealand
    Default ae86 rust removal
    Hey guys,
    Been long time lurker and just registered an account.
    From New Zealand and purchased ae86 for a few months, finally had a chance to work on the car.
    Just stripped the back and realized theres a lot of rust.
    Under tail lights, quite a bit. The hatch is fiberglass so thats okay, but the hatch opening thats under the weather strip has some rust too.
    These parts, I'm confident I can deal with myself which I'm okay with.
    Big question.
    This area behind the B pillar. ie behind the "side" of the car.
    What can I do to reach in there to tidy that part up?
    Please advise.
    Thanks!
    Cut an access hole and stick a new bit of metal in and weld up the access hole again for areas u can't get to.
    I'd fish oil that and then prime / paint it.
    Veteran McLEVIN's Avatar
    Nov 2010
    What thickness metal does one use
    MOPAR or no car!
    Aug 2010
    Geoff
    mt dandenong
    That rust isnt too bad. Get rid of as much of it as you can with a wire brush and use a good rust converter like galmat ironise, when dry spray it with some por15.
    Ive had good results with that process
    Dec 2013
    Doug
    Auckland
    Auckland
    New Zealand
    What does it mean to fish oil?
    Thanks for asking, I'm also interested in the answer to this.
    Will definitely give this a try, will head to bunnings asap.
    Veteran drift kid's Avatar
    Glossodia
    Most "body steel" is .9mm thick but in more structural areas it can go to 1.5mm
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    If you're unsure at all, I would probably leave it to the professionals. I have seen some repairs done by people at home that looked okay on the outside and some even lasted a while, but even in a small crash there was significant damage because none of the work was strong enough. Considering these old Toyota shells aren't exactly rigid to begin with I would be very careful.
    E-Famous (Remeber your roots)
    Forget it's there and drive!
    Veteran biggo's Avatar
    Nick
    Noosa
    i use 1.2mm zinc sheet on my rust repairs.
    do it right and it will be stronger than the rest of the car. You will have to clean it after welding though.
  1. Rust Removal Tips n Tricks
    By Matt in forum Restoration / Body Work
    Last Post: 5th November 2015, 11:49 AM
  2. Rust removal
    By lawrencelalot in forum Adelaide & SA Events and Discussion
    Last Post: 16th July 2010, 09:01 PM
  3. Budgeting for rust removal - How much did you pay?
    By matttai in forum General Topics (No Technical Questions)
    Last Post: 25th June 2007, 01:28 AM
  4. help with rust removal diy
    By alan70 in forum Technical - Questions
    Last Post: 7th June 2006, 11:07 PM
