Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Ae86 300hp diff ratio questions
  1. #11
    Paul
    Nathan if it is making full boost by 3000rpm then I would be going with the 3.9 you have plenty of rpm to play with and with the longer diff ratio's it will be a little more forgiving on the track if you are just starting out.
    Paul
  2. #12
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Ok yea was a guess really on the 3000 as rev gauge not working, How do u know when u have hit full boost i have a dyno sheet would that show me? Yea i will be just starting out on the track.
    Thanks
    Nathan
  3. #13
    Paul
    I just run a video camera somewhere so I can see the boost gauge and tacho. To be honest though I would be thinking that if you are running a TDO5 with 20G compressor you are not going to be making meaningful boost until 4500rpm. If you have your dyno sheet with the tractive effort on it, not power that can be useful as you can look at how the engine is responding to the boost.
    Regards
    Paul
  4. #14
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Paul is correct. Having a td05 16g evo 4 turbo, full boost isn't until 3800 ish rpm.
    That is a stock smallport gze head and bottom end.
    18psi on ultimate 98 will have to check afr.
    Looking at cam options at the moment and installing valve springs.
    Has a 3.8 ratio f series and suits well
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  5. #15
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Ok thats a good idea i have to get the rev gauge fixed then go from there. Yea you are probably right. It seems to boost fine and isnt real laggy but i have the cams as well 272/264 no head work thou, will do so on next smallport 4age one at the moment is bigport. Not sure what you mean by tractive effort on dyno sheet? Mabe i could email you the dyno sheet?
    Thanks
    Nathan
  6. #16
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Yea mine is running 18psi also and 98 octane fuel. What cams are you thinking of going with slimer86?
  7. #17
    Paul
    Nathan, if you want to email it through to I am happy to have a look. I have attached the dyno print from my engine, this was basically a run in tune as it was only pushing 12 psi. I am running a T25g on mine with E85.
    Also a dodgey shot of the car on the track.
  1. Team Fine 300hp 4AGTE AE86 Trueno
    By PeakingDuck in forum Offtopic Discussions
    Last Post: 25th December 2009, 01:04 PM
  2. diff ratio question
    By steroidchickens in forum General Topics (No Technical Questions)
    Last Post: 9th December 2009, 10:27 PM
  3. wtb 4.7 diff ratio,
    By brad in forum Cars or Parts Wanted
    Last Post: 24th March 2009, 07:35 PM
  4. 4.56:1 diff ratio E series diff
    By Clemo55 in forum Cars or Parts Wanted
    Last Post: 25th September 2008, 04:29 PM
  5. ke70/ae86 diff ratio's????
    By ae86dave in forum Technical - Questions
    Last Post: 23rd April 2006, 08:36 PM
