Results 1 to 10 of 16
Thread: Nihon Garage custom parts make.
    Veteran drift kid's Avatar
    Glossodia
    Default Third Strike Fabrications.
    Hey guys, I have been modifying and fabricating custom bits and peices for quite a variety of Japanese cars over the past few years and it has slowly been picking up in pace, so I thought that it would be good to try and widen the spectrum of potential customers.
    The majority of what I do is cut and shut steering knuckles for big steering lock and faster steering, I also have done many lower control arm setups aswell which include lengthening, shortening, boxing in the underside for rigidity and scalloping for further steering angle. But this is not the extent if my skills, I am trained in structural welding and am qualified as a sheet metal fabrication engineer, I can do basically anything related to these feilds. 99% of my work is TIG welded and ALL of my steering/suspension modifications are TIG welded.
    At this current point in time I do not have a great expanse of space available so sadly I cannot have entire cars come to me for long periods of time as I have no where to store them, but smaller items such as steering knuckles, control arms, exhaust parts etc. are welcomed. So if you have any quieries or would just like to run something by me don't hesitate to ask.
    Cheers, Ben.
ID:	30738   Click image for larger version.
ID:	30739   Click image for larger version.
ID:	30740   Click image for larger version.
ID:	30741   Click image for larger version.
ID:	30743   Click image for larger version.
ID:	30744   Click image for larger version.
ID:	30745   Click image for larger version.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    The quality of your work looks fantastic, really neatly finished.
    Glossodia
    Thanks man
    Glossodia
    Here is some more general fabrication done by myself.
    Custom cross member with rack mounts moved forwards 25mm and solid mounted, lca holes made adjustable and skid plate welded to the undersideClick image for larger version.
ID:	32472Click image for larger version.
    Another sump for a customers v8 ute conversionClick image for larger version.
ID:	32474Click image for larger version.
    Intercooler piping modsClick image for larger version.
    Glossodia
    Stainless tig from workClick image for larger version.
    Full exhaust systemClick image for larger version.
ID:	32479Click image for larger version.
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Hmm looks good dude. PM me rough prices for full exhaust turbo back for my AE86
    Glossodia
    More stainless work from today, i am getting fairly confident with my tig work now.
ID:	34179Click image for larger version.
ID:	34180Click image for larger version.
ID:	34181Click image for larger version.
    Mar 2013
    Mirko
    What you setting your machine on?
    Glossodia
    The tabs on the tube were 28 amps, no pulse
    The end in the tube was 30 amps
    The fuel tank was welded on roughly 60amps (2.5mm sheet)
    Glossodia
    Some of my recent fab work
ID:	34615   Click image for larger version.
ID:	34616   Click image for larger version.
ID:	34617   Click image for larger version.
ID:	34618   Click image for larger version.
ID:	34620   Click image for larger version.
  1. Anyone make custom hub adaptors?
    By jet111 in forum Technical - Questions
    Last Post: 17th May 2011, 11:28 PM
  2. Does anyone still make custom springs?
    By KePtrick in forum General Topics (No Technical Questions)
    Last Post: 10th February 2010, 07:07 AM
