Here is a tip ----- if you are trying to take out the side winding windows and you find a nut that has seized . Then cut a access panel and the job is done . Not so good if the car is a keeper though --- bit drafty.
Body has had rust repaired, dents manicured and undercoat applied. So after final sanding , should be ready for color on the body in a couple of weeks. Then onto the panels ! Bloody weather is crap again thou.
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
Bit more done ------ got some color on the body , panels not ready yet , but hope to get them done before it gets to cold to paint.
Nice progress on the red one mate, pity I've seen this late. I'm assuming the tape deck from the brown one has been turfed?
NO not turfed --- both cars had the tape decks trashed before I found them. I did find one at a wreckers down your way but he wanted 3 times more than what I payed for both cars , so I passed on that deal.
Harcourt Auto wreckers?
Yah ! I think that was them . Missing a couple of the side protector strips ------ they quoted $250 for the whole set . And they say t18's are not worth anything ?
Which ones do you need?
The only one's missing on both cars where the right and left door mouldings . I have all the others.
I'll have a look to see what I have. Keep me in mind if you come across a tape player, mine is missing the flap. Dad's going to strip a series 2 T18 soon. I'll see if it has door mouldings.
