speak to still steppin
he needs some bits
Found these TE72 (T18) on a farm near Canberra . The red one to have a tidy up and put on historic rego , the brown one to be wrecked where she lies and then scrapped. ( riddled with rust but good for parts).
Pretty chuffed with the red one , it has a rebuilt 3TC donk , gearbox is sweet , diffs bit noisy and will be a 3.9 ratio ( but I have a t series AE86 4.1 rear end in the shed with new every thing ) so that will be bolted in.
It has been siting in a paddock under a tree for about 3 years . Once we got a key ( they had been lost ) I put a battery in it , turned the key and she fired up and ran sweet as. When I got here home got out the 4000 PSI pressure washer and while still on the trailer , I went fully sick. Found almost no rust ( most ususal ) and Lovell coils all round plus Kmac sway bars front and rear and 2 INCH exhaust .
Another Toyota Saved and even better it will be used .!!!!!
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
he needs some bits
indeed i do...
What are you after ? The red one is a keeper and the brown one is being parted out , but is poor condition .
engine bay wiring, including fuse box, all the heater bits under the dash including heater box, dash pad (pending condition), interior pillar trims, front windscreen wiper arms, rear washer bottle, i think thats it
Chris , I am wrecking the brown one where it is on the farm , its a quite a bit out of Canberra . I am not due to go back out there till next week . I will see what is worth salvaging from the items on your List. Some bits I may need myself but other bit will be available for sale. I know that the dash pad is totally stuffed , but the other items I think are ok . I will let you know. Cheers BOB
no worries, appreciate it!
We have a bit progress on the T18 . Bought F/R KYB G's of the net ( really cheap ) , a rear hatch seal at the right price and the shocking paint has begun to disappear.
Other than surface rust in the cracks of the bad paint , this the only rust in the car.
The paint stripping is done by roughing the paint with 40 grit , paint stripper and then using a 4000 PSI Pressure wash machine to blast it.
This works well for me , quick and easy ----- wash , hand wipe some dioxine , wipe off with a clean moist rag , let dry , prep wash and dry --- then on with a couple of coats of a good etch prime.
The roof and pillars are now in etch and the rear quater are done , on to a bit of rust repair .
Panels now stripped , etched , dents knocked out and primer done.
good progress!
