I used the Weber bottom fitting kit on twin DCOE's on a right hand drive car. With a little mod (enlarged linkage hole by 1mm for cable barrel end to fit in) it fitted with the AE86 throttle cable.
The linkage is versatile and you can buy individual parts to change from top to bottom mount or spares as required.
