What you have said is correct.
Yellow wire is for charge light
White wire is for 12v constant
Red is for ignition power
Run the wires from the alternator along the bottom of the radiator panel and join up to near the fuse box. You can pick up ignition power from behind the washer bottle. I usually join the white wire into the thicker battery cable and run the light back to near the fuse box.
