From memory if you just run the external pump they wear out quicker than if you don't have an internal pump too
but don't quote me on that!
Going with a cut and shut, I want to go air box put probs just pod
So today I got busy cleaning all the old parts out and cleaning it and blah.. Blah.. Blah......
but I did order some parts
like a fuel pump....
Haha
as of that I need to order
dizzy cap, rotor button, leads, plugs,
cause all that stuff is molested....
I also brought a intake and exhaust so that should be cool.
does anyone have info on how to wire the 4age in....
Took the old ke70 seats out to get ready for some celica seats... Yay
run one of these and use a Facet 7psi external lift pump connected up to the standard feed line like so .
don't use an in tank VL pump on the standard in tanks pipes, it will give you nothing but trouble, had mine fall of and float around inside the tank a few times. plus you have to drop the tank anytime you have a fuel problem which get annoying.
Well have most of the parts of the parts have trd copy extractors, cut and shut intake, just have to sort out the loom
" IF ANYONE NEAR LISMORE KNOWS HOW TO WIRE IN A 4AGE INTO A KE70 PM ME ILL GIVE YOU FOOD AND MONEY FOR YOUR HELP "
now for fuel fuel im not gonna go cheap I'm gonna get a 1.8l surge tank with a facet 7psi pump then a vl external pump so when I do full sicckk diff with 1/4 of fuel it won't surge hahahaha
I just brought a ebay surge tank... Where the best/ cheapest place to buy a facet pump??
Ok i started connecting up the loom and stuff and found that the O2 plug is different It has a flange on it where in the extractors it's a screw in type?
Can you just unscrew the flange??
Take the extractors to an exhaust shop and add a flange where the screw is won't be more than $30-40
Well some gasket came yesterday
brought some parts off a guy and they never showed.. Loved getting ripped off
Only need fuel pumps, surge tank, have everything else I think
but I just pay for 6 months rego and I need to buy another car
cause i I brought a stock white ke70 off and old lady and 2 days later my " friend " drove it into the back of a ute and wrote it off!!
So I'm gonna buy another ke70
so parts on this is going to be on hold for a little bit,
this thread has pretty much has died in the ass!!
well replaced lead's, plug's, dizzy cap, rotor button. water pump, all this other stuff
now its ready to go down and get wired in then I can tune it and drive It
;0
