Results 1 to 10 of 42
Thread: Moonlight Garage - The Peugeota - 1JZ Peugeot 504
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default Moonlight Garage - The Peugeota - 1JZ Peugeot 504
    Bonjour!
    Now, I have just bought another Peugeot 504 after a 13 year absence from Peugeot's. I grew up in Melbourne, and my Father was a Peugeot mechanic/nutter for 30 years, so I grew up in an exclusive Peugeot 504 household. Therefore, I have a soft spot for the great cars...
    In my teenage years, I had many Peugeot 504's, and ended up having 4 at once. Being the late teenage age, I got the hunger for more powerful cars, and I sold up all the pugs, and got into Toyotas.....
    I am 32 now. For years, I have wanted to get another 504, to modify into a track capable car... I have been searching for a good cheap one, as I didn't want to molest a nice 504...
    Alot of people will be shaking their heads at this idea, but I am doing it to make something unique, and know I still have the appreciation of why they were such great cars.....
    I have picked up a 1973 504 GL, White in colour, manual, very minimal rust (lifetime inland car), 326,000kms. The car is complete and runs well... Just out of rego.....
    The plans for the car, will be a Toyota 1UZ V8 engine, W58 5 speed Supra G/box, Toyota AE86/RA40 coilovers (10kg spring, height and damper adjustable), Adjustable rose jointed Lower Control arms, adjustable caster rods.
    Rear diff will be a VX commodore diff. They have mounts on the top of the diff in a similar position to the original Peugeot diff... I would have liked to use a Toyota diff, but their mounting points are totally wrong for this application. The rear brakes/hubs etc will also be from a VX rear cradle. Rear will have custom height and spring rate springs. (Stiff!)
    I will be doing all the work myself, so I will update here of any work done.
    EDIT: Plans changed, and the car will run a Toyota 1JZ-GTE 2.5L 6cyl motor
    A bit of info for people who don't know these cars:
    Production from 1969 to 2005!
    They were rwd, had 4 wheel disc brakes, IRS, MacPherson struts, rack and pinion steering and are very solid cars, but sedans still only weighing in at 1230kgs. Amazing car for 1969+ etc....
    They are well known for dominating the rallys back in the day..... They are amazing cars on dirt roads and rough surfaces.
    Great for towing, with a towing load rating of 2 tonne..... Very underpowered though.
    JoJo
    ACT
    Tuggeranong
    A bit of motivation
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Jo Jo you never cease to amaze ! But these are a cool cars , with features way before there time. I have never owened one but driven a few , including a highly modified one in the Wynns Safari . It did not finished the year I was part of the crew , but did a few years later when the course was not so 4WD only . This a way out there project and even though you are re-enginerring this beastie . You should talk to Jim Taylor , he was at the last hillclimb driving a Cleo with his son. He is a 504 nutter , had heaps of them over the years , he was the owner and builder of the Wynns Safari car. Also has an Historic rally one at present and does the long distance outback rallies , pretty sure he is doing it again this year. Worth have a chat with.
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    Aug 2010
    Geoff
    mt dandenong
    Alien?
    Nice cars, quad lights and chrome bars standard
    That production time is almost as good as the original mini 58-02, keen to see this progress. Always nice to see something different
    JoJo
    ACT
    Tuggeranong
    ^^ I have no idea why there is an Alien in the pic ??????????????
    ACT
    Compton
    Oh no,not another project! I better get that extra long visa now boy!lol
    JoJo
    ACT
    Tuggeranong
    Just passed rego, so now the fun can begin
    JoJo
    ACT
    Tuggeranong
    Here are some pics....
    Rose joint with machined weld in mount-
    Spacers made for the rose joint/Peugeot mount (41mm inner mount spacing) -
    Weld in mounts cut to shape -
    Raw finished product -
    EDIT: The 41 mm spacers above were infact incorrect. I had new ones made up as the spacing is actually 43.5mm
    JoJo
    ACT
    Tuggeranong
    Here are a few pics of the suspension and front brakes I will be running....
    AVO Rear Coilovers - Height and damper adjustable -
    Front Toyota AE86/Celica RA40 modified coilovers -
    Front big brake kit - Big PBR calipers, 295mm rotors, cross drilled and slotted -
    Also, the Steering wheel boss kit arrived today (made in Italy) and fitted a more suitable steering wheel -
  1. Replies: 34
    Last Post: 26th July 2015, 01:44 PM
  2. Replies: 11
    Last Post: 12th May 2015, 12:30 AM
  3. JZS147 ARIS-TOW (Moonlight Garage)
    By maxhag in forum Other Toyotas
    Last Post: 25th August 2014, 04:22 AM
  4. Do it all again..... AE71 Highroof Panelvan - 4AGTE - Moonlight Garage
    By maxhag in forum KE70 / AE71 Owners Forums
    Last Post: 16th August 2014, 06:35 PM
  5. Replies: 128
    Last Post: 2nd May 2013, 12:44 AM
