I've got a thermostat cover with outlet here that will do the job, bolts up and points in the right direction, want $30 for it, can throw in a cardboard cereal box for you to knock up a gasket if you like
Hi, Need a thermostat outlet housing and gasket for a RWD 4A-GE. In SA
0401155970
-Thanks
sounds good, where are you located?
PM'ed you bud, might just txt you aswell
...the number in your 1st post is incorrect - the random dood I just txt'd replied "wrong number mate"
