Results 1 to 10 of 15
Thread: What rear end gear ratio should I run?
    Jun 2014
    Ismael
    Untied states
    East side
    California
    Default What rear end gear ratio should I run?
    I am about to start drifting in my corolla but broke my old gears and not sure on the gear ratio of them but I am buying new ones and was wondering what would be a good gear ratio for drifting. AE86 corolla F series diff. Thank you.
    Eddie
    Out of curiosity, what motor are you running to break f series gears? NA or turbo?
    Jun 2014
    Ismael
    Untied states
    East side
    California
    I have the 4age 16v stock motor plus my motor isn't running 100% it feels like it restricted at low end but when I hit 4k rpm it picks up speed so honestly I think the guy I bought the car off abused the car before me and the gears were worn down already. I wanted to see if the car would do dounghts but it wouldn't have enough power it only let me side out to do a 180 and then I lost power I tired 5 times then the next thing I knew I was hearing gears in the back hitting and as I drove home they broke on me didn't lock anything up just sounded and felt really nasty.
    Eddie
    I am suspicious that you have broken an f series in there, especially since u have an NA 16v. Are you sure it's not an S or T series?
    Veteran blair's Avatar
    Blair
    SEQ
    borgy fo' sho'
    Veteran Konakid's Avatar
    Henry
    Eastern
    Get under neath and take a good clear photo unless you konw for sure its an F series?
    If so you should find a 4.3 ratio they are quite rare. Search toymods for more info on F series ratios and what chassic codes they came from.
    Jun 2014
    Ismael
    Untied states
    East side
    California
    Are these good enough pictures??
    Eddie
    Measure the crown wheel od. 7.5" will be f series. 6.7 is t series, 6.5 is s series.
    Jun 2014
    Ismael
    Untied states
    East side
    California
    okay so I have a 6.7 with is T series thanks man for all the help. Is there any I can get gears for this?? Or upgrade to a 7.5 with I thing upgrade means the whole read end right??
    Jun 2014
    Ismael
    Untied states
    East side
    California
    Can I put an 8" hilux rear end on my corolla from a 86 toyota 4tunner.
  1. Differential Gear Ratio
    By mikare in forum Technical - Questions
    Last Post: 16th September 2014, 08:49 PM
  2. w57 close ratio gear box
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 28th August 2011, 10:09 PM
  3. Gear Ratio (Final) Selection?
    By assassin10000 in forum Technical - Questions
    Last Post: 15th August 2011, 10:24 PM
  4. Differential Gear Ratio
    Last Post: 23rd September 2010, 10:22 AM
  5. gear ratio and speed -w50
    By redsprinter in forum Technical - Questions
    Last Post: 8th September 2009, 01:13 PM
