Look for the used stuff. You can use vice and some ingenuity . Think ball joints are retained by clips from memory.
looking at getting a decent press, but is there any decent ones to go for?
head to your local total tools. they have a decent range. We picked up a 12ton press for under $250.
ALL DRIFT MODIFICATIONS
See the sponsors section 4 details!!
you could go for used stuff, but when your talking about up to 10 tonns of pressure on something you dont want it to explode in your face because the pevious owner has mistreated it.
Also balljoints are pressed in as well as a retaining clip.
good luck
leo if you need anything pressed out, come out for a drive my way, i've got a 30t press
you can get those "presses" that all they are is a hydraulic jack (little one that you get in utes) and a frame. for bushes and ball joints i think that setup would be sufficient. i think brand new they are only about $300 or something, including the hydraulic jack. thats not bad considering that the jack is "worth" about 150 or something in the shops.
in most jobs on a car it is not that you need a massive amount of force applied, its just that you need a consistant amount of forced applied equally. and also the ability to easily apply force so you can concentrate on making sure its beign applied in the right spot.
here we go! this is what i mean.
- Blaise Pascal
Keep an eye out on ebay, the little 6T ones regularly go for $70-100.
how are arbor presses for things like ball joints? not enough force?
Just don't get a chiwain cheapie. (less than $200).
We bent the press pin on the one at AJPS. Well, I bent the press pin. Fuck knows how, either.
I have a china cheapy, cost me $75 off eBay.
The press pin bent pushing MA61 rear stub axles out. So i merely welded a piece of solid 25mm round on instead and reinforced the join.
Problem solved.
