Front or rear? Assume it's an ae86. Stock suspension/coilovers/lowered?
Just wondering what is needed to fit a wheel that is 8j with et25, don’t ask me the type of wheel that’s a surprise, i just want to know whether i need spacer etc…
thanks
MRO Supply
Its front, stock suspension??? not sure about that.... need to be checked again
Need the diameter of rim as well as tyre you're planning on running. Id bet it won't fit though. You'll hit strut/spring. Might fit on rears with no mods.
+25 wont fit it will foul. you will need a 20mm spacer minimum.
I run 16x8" +10 with 215/45/16 semis and they clear with no spacers. It is damn close though.
