Did a little more cutting have gone from 8kg to 5.7kg
Yeah I will be
The rear I'll be welding a section to rear door as they are going to be welded shut remove door handle and so on
So I can just rivet them on
It allit all counts, keep at it
Started on the abortion bog job on the weather strips
On the up side no rust on the passenger side
Well had some fun today welded in a steel infill ground back
Bit of filler and prime not to do the other side
Cut the fuel flat out as deleting it
Used a slide hammer to get some of the section of the quarter where it should be
Damn! That bog work
None really in it now how it should have been done in The first place
For the look old mate wanted
I looked at fixing it but was going to be
more work to get the nice chrome strip for it so just weld it up only going to be a track car
But couldn't leave it the way it was
Managed to finish the other side
Now the rest of the roof and then panels
But more cutting and before I get some telling me
that is on bump stops and yes I know about the panhard still more work until I move on to suspension
1kg removed
And total for the sound deadening was 16kg
