Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Headlights Playing Up. Switch, or Relay?
  1. #11
    Oldschool Member
    May 2006
    Tan
    i had some loose wiring under the dash. wiggled it around and it all started working.
    Best way to check where the issue is, get a multimeter. Check if there is anything coming from the relay. If not then there is an issue between the relay and switch. Otherwise, the headlight bulb plugs might be dodgy.
  2. #12
    Aug 2012
    Jarrad
    east
    Digging up an old thread thread, I know. But a good place to keep this issue in one place if it is common.
    I have the exact (to the T) issue in my car at the moment. I had previously had headlights and dash lights.
    I pulled out my headlight switch and resoldered all the joints which now gives me dash lights.
    However, still no headlights. All the others work, with the high beam globe stuck on.
    Did you ever get around to finding a definite fix to this problem?
  3. #13
    Looking at the wiring diagram above, when you flash your lights it bypasses the headlight switch. My feel is your headlight switch is still faulty.
    id try a new headlight switch first if you can find one, failing that as all the switch does is provide a ground to the head light relay you could earth it as a test temporarily
  4. #14
    Dim
    Menai
    Jrad 0- I did solve this problem.
    I think there was a dodgy connection in the plug that sits on the steering column. It appeared excess heat had melted the plug in a place and cut the connection for the main headline wire.
    I had a pry the plug apart, and replace the pins then it was all good!
  1. Blower Relay and Tail light Relay connections to 4age 20v ECU.
    By paulv in forum Technical - Questions
    Last Post: 9th January 2012, 01:33 AM
  2. light relay switch
    By Julz in forum Cars or Parts Wanted
    Last Post: 13th July 2009, 08:28 PM
  3. AE86 head light switch and wiper switch
    By cando1 in forum Car Parts For Sale
    Last Post: 27th January 2009, 01:02 PM
  4. IGNITION SWITCH AND KILL SWITCH
    By bigpuppa in forum Car Parts For Sale
    Last Post: 29th June 2007, 11:32 AM
  5. head light switch and wiper switch
    By Johnny_08 in forum Cars or Parts Wanted
    Last Post: 5th May 2007, 09:31 PM
