i used to run 130/90 in my ke70 with standard wiring. would have been better with a relay setup but was good enough.
never had an issue. with any of it. was like it for roughly 2 years.
Anyone used higher rating halogens in their ae86 I've upgraded my wiring harness to handle 130/90, 100/55, 100/90 just wanting to no if anyone has used anything higher then 60/55w in their headlight without melting the reflector or lense silicone
did it make much of difference compared to the oem 60/55 watts? Also did ur reflectors ever need replacing
I found that the google translate version made a lot more sense.
does anybody know if you can fix the adjusters by cracking the light open like this, mine are stuck pointing up, hardly no light on the road at all, and people flash there highbeams at me cos they think i got mine on.
hey there kim. i think the best thing you can do is buy raybrig lense and do HID conversion also.
yes rx7,mr2,hiace most cars with popup lights and a lot of "comercial" type have the same lense.
a couple of quick questions
does anyone upgrade there wires when they install a hid kit and has anyone bought or heard of these guys cause it pretty cheap and i know its only for low beam but $100 for a kit
and does anyone know if these would fit the adm sprinter, just double checking cause they usually put ramdom car makes on there list or is it more of a driving lights not head lights
for the 2nd link yes and no, they only fit trueno's fronts
this type of light setup is also used in i think s13, even some hiaces
all this talk and no mention of installing projector lenses and polishing the original glass. I should do it and post some pics, ah too much to do...
old thread but has anyone accomplished the fitment of these ae92 reflectors into ae86 headlights?
BENT MECHANIX - Garage 20:
