Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: 500hp 70 drift build
  1. #21
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    take the rca off the knuckle, sit in on square and tap it down evenly with a soft faced mallet while supporting the lca/balljoint with a jack. they are tight for a reason.
  2. #22
    Oct 2015
    Jayden
    Wa
    Woodvale
    Will try tommorow but I doubt it as the knuckle is out by atleast 1-2mm
  3. #23
    Eddie
    Sounds like you either have ke70 struts or ke70 knuckles. They are about 1-2mm narrower than the ae86 gear.
    Sent from my iPhone using Tapatalk
  4. #24
    Oct 2015
    Jayden
    Wa
    Woodvale
    They were sold to me as "ae86 cut and shut shortened knuckles" they are a horrible backyard job imo
  5. #25
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Talk to Brenton Lapworth then and get some better steering gear. I got mine from him, he does really good prices and his work isn't dodgey...
    Last thing you would want is to have a steering arm snap on the street after spending so much time and effort building a 500hp streeter.
    Current Cars:
  6. #26
    Oct 2015
    Jayden
    Wa
    Woodvale
    havent updated in a while but a heap has happend in the last few months,
    me and my old man moved in to our workshop so we now have a dedicated place to work on our cars and chill out. hoist, compressor, tools and cabinets have been added so far. bar theartre room kitchen to come.
    i got straight to work and started by removing the old 4k and tore my front end down and powdercoated everything black.
    lots of parts have arrived including hubs, xt130 arms, lock spacer, bushings, coilovers and more,
    most of my front end is together all freshly powdercoated. i want everything fitting up before i decide to paint anything else.
    boxed up my xt130 arms, unsure if i should remove the steering stops (engineering and rego) but i would like to find out before i powdercoat them.
    my ke conversions engine mounts and pedal box arrive and i dropped my motor in for a test fit, looks good although it hits my greedy copy plenum on the brake booster, so am curious to see if anyone else has had that problem and how they got around it? im going to scallop it out and weld it back over if there isnt a easier fix.
    everything is going smooth so far but i feel i might run in to problems with clearance for my rb25 box clearing the tunnel, will find out tommorow night when i test fit the box.
    restoring my brake calipers in the coming weeks and hopefully some changes for clearances.
    heres some pictures so far. update again soon cheers[IMG][/IMG][[IMG][/IMG]IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
  7. #27
    Veteran AJPS's Avatar
    Lonsdale
    definitely remove the lock stops - they didnt have them factory
    also dont forget your locking nuts on the tie rod tubes (they are missing in the pics)
  8. #28
    Oct 2015
    Jayden
    Wa
    Woodvale
    Going to cut them off tommorow and finish them nicely so I can drop them at the powdercoaters and then have my bushes pressed back in the following week, as for the tierods, almost certain they didn't come with locking nuts.
  9. #29
    Lonsdale
    definitely would have been in the box, but can send you some more if you dont have them, send me your address to
  1. ke-70 13bt build
    By Turkish-86 in forum KE70 / AE71 Owners Forums
    Last Post: 6th May 2012, 07:26 PM
  2. Brendon's drift 70
    By thr55t in forum KE70 / AE71 Owners Forums
    Last Post: 20th December 2011, 09:34 PM
  3. Ke 70 Unfinished Project Drift track car
    By freak in forum Cars for Sale (Toyota Only)
    Last Post: 7th September 2011, 09:13 PM
  4. Japanese ke 70 drift pigs..Videos
    By 24 yr old Two door 86 in forum Toyotas in the Media
    Last Post: 11th December 2007, 08:37 PM
  5. DrIfT SpEc 70
    By rOlLa DrIfTeR in forum KE70 / AE71 Owners Forums
    Last Post: 15th January 2007, 07:01 PM
