Results 1 to 10 of 10
Thread: Bad vibration. Thinking gearbox????
    Senior Member ae86 drifter's Avatar
    Pete
    Default Bad vibration. Thinking gearbox????
    Hey guys I've got a vibration issue when at higher speeds above 100km\h. its got me stumped.
    whens are brand new and balanced,tailshaft has been balanced twice.
    Its got me thinking its the t50, speedo gear has stripped the nylon gear. there is no noises or gear shift problems.
    Anyone else had the same problem???
    regards pete
    ROYAL GARAGE NEWCASTLE
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Check both engine mounts and the trans mount. Use a pry bar or completely remove them to verify. If the vibration is not gear related but speed related it could also be a tire. Dave W
    Pete
    Hi Dave thanks for the advice, engine mounts are trd items and basically brand new. have checked them out today. What would I be looking for with a tire as the rims are new and balanced.
    Tan
    West
    Sometimes tyres are just shit even if new & balanced, e.g. defected I had one of those dunlops from ebay which would vibrate at 60km+
    Systematically isolate the issue. e.g. swap the rears to front. if its tyres you should feel the wobble through steering or the sound should be slightly more audible. Swap out suspect tyre for a spare.
    Good luck. I once had a shitty vibration sound, stripped out everything and it one day I discovered it was the passenger seat adjustable spring...drives ya nuts.
    Pete
    true ill check it out. I've had this vibration for over two years. gotta get to the bottom of it as its driving me nuts
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Tail shaft bolts all tight?
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    West
    Twisted axle?
    is it worse on acceleration / deceleration?
    Pete
    so I've had the car up on the hoist and done some rough angles on the pinion and and its way outer back. motor and box have roughly 4 degrees down from factory, and I've measured the pinion and its 2 degrees down, Meaning the parallel aren't parallel. more investigating to come. higher speeds above 115km/h.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    sounds like the tail-shaft needs the balance checked
  1. Vibration
    By tea18 in forum Technical - Questions
    Last Post: 22nd February 2011, 08:12 PM
  2. One piece tailshaft vibration
    By Tom86 in forum Technical - Questions
    Last Post: 25th June 2010, 01:06 PM
  3. Vibration through steering wheel?
    By dave2221 in forum Technical - Questions
    Last Post: 26th December 2008, 01:38 PM
  4. Vibration..
    By Thats_How_We_Roll in forum Technical - Questions
    Last Post: 23rd September 2008, 06:26 PM
  5. Gearknob Vibration..
    By Dish in forum Technical - Questions
    Last Post: 15th January 2007, 11:41 AM
