Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 21 to 30 of 77
Thread: who has drifted with a 7ag??
  1. #21
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    talk to felix, i believe he had one in his car once
    ~KEEP DRIFTING FUN~
  2. #22
    id certainly hope that i dnt have any kind of troubles with the money being thrown at it, itll have everything basically and be tuned rather safe...
    everything is being taken into account...oiling system, bullshit cooling, lightweight components, billet crank...but yeh, definately a fun process without throwing money at yager to build one of there proven IPRA packages...
    pfffttt...engine will be built soonish...unless i decide to go with the billet crank...give me 18months and i rkn we'll be finished...lend me 20g's and we'll be done within 6 months..
    for the price of aftermarket rods its definately worth the effort...i paid good money for the lightest reasonably priced rods i could in the belfab ones...spool ones are quite affordable, but ive managed to track down some quite reasonable ones down for less than $400AUD...
    the problem with the rod bolts is the fact that generally the stock rod bolts pull out of the rods...a few ppl have machined the rod to accept a 4age style rod bolt but for the hassle prolly alot easier to purchase aftermarket rods and get ARP's or similar...
  3. #23
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    lol, i was joking lazy!
    yours will be sick when finished! i just wanna get back into a 4a powered bus for the next two rounds and looking at my options, my old carb fed bigport struggled and the 20v was mint for power but is prob a bit over what i wanna spend on my car
    NEAR MISS
  4. #24
    til the day its all together,running and im happy with it, ill bite my tongue...itll look shit hot no doubt about that...but engine wise...we'll see...playing with a emgome combo that isnt exactly proven yet and spending alot of money doing so isnt a "safe feeling"...but cars, we love them for that reason
    think im going to get the tunnel refabbed slightly larger during the process to replace it with a nice clean workable sr20/beams conversion when it proves me wrong and everyone else right and blows up big time...
  5. #25
  6. #26
    Ok
    Seamus
    Milton
    Nick teeboon had a 7AGE (standard, NA styles, with smallport pistons instead of the 7A ones) .. went well, then he upgraded to 4AGTE or something
    And that red caldina (?) in NZ has also been drifting one for a while, turbo'd as well. No engine problems so far. See first vid for awesomes
  7. #27
    Senior Member Intense's Avatar
    Aaron
    Don't 7afe's have a pretty low redline around the 6k mark? Is this limited by the flow of the head or by the strength of the pistons and bottom end, considering it's just a stroked 4afe.
    And theirs lots of talk of engines failing, but what specific part failed? Like on Lukes ae86, what happened to the 7age in that? Was it a bottom end bearing or did it do something cool like blow a hole in the block?
  8. #28
    pretty sure this is a blacktop 7age with 220hp +80hp nos.
    ok sorry its a hks stroker 5ag
    Specifications
    Engine:
    * Black top 4AG (20V)
    * 82x83 (1750cc)
    * Precision built by Prime Garage, Japan
    * Dry Twin Shot NOS System
    Cylinder Head:
    * Combustion Chamber Processing: Machined head to match combustion volume
    * Intake & Exhaust port grind
    * Intake & Exhaust valves shape modification
    * Valve seat cut + set length match
    * Valve seat Prime Original
    * TODA Valve Springs
    * TODA Cam Sprocket
    * Camshaft Intake & Exhaust Prime Original
    * Valve Lifter chamfer processed
    * TRD Head Gasket
    Block:
    * Inner Block sand blasted
    * Conrod clearance processed
    * Tomei Crank Cap (Main stud & ladder set)
    * Upper Block resurfaced
    * Special boring & honing process
    Engine Internals:
    * Droo-P special Escort Pistons
    * JUN Automotive Conrod (I profile)
    * HKS 5AG Crank (Balanced, curve correction, wrapping)
    * Special Order Toda Racing exhaust manifold
    Engine Management:
    * HKS F-con V pro ECU
    Engine Cooling:
    * ARC 3 row radiator
    * APP Oil Cooler
    Cockpit:
    * Recaro Seat
    * Takata Harness
    * Nardi 330 Steering Wheel
    * Works Bell Rapfix II Yoshioka Model Quick Release
    * Works Bell Paddle Shifter kit (installed as nitrous oxide switch)
    * HKS water temp / oil pressure meter
    * Autometer tachometer
    Bodyshell and bodywork:
    * AE85 bodyshell (see note below)
    * Vertex Body Kit
    * FRP Engine Hood
    * FRP Door
    * Lexan windows
    * Droo-P Headlight cover (for Trueno)
    Drivetrain:
    * HKS FC3S 5 Speed Dog mission converted
    * ORC Metal Clutch
    * ATS Carbon LSD
    Footwork / Suspension:
    * Kei Office shock absorbers with DG5 processing, Full Tap & full length type, 16 levels of adjustment
    * Eastbear Pillow front arm & tension rod
    * Pillow lateral bar
    * Droo-P Titanium control arm
    * Espelir Springs
    Wheels & Tyres:
    * Rays Engineering CE28N Front 16in / Rear 17in
    * Advan Neova Tyres
  9. #29
    Scammer, DO NOT BUY FROM ME!
    ok looking at that video before could i just say this
    Just because an engine CAN rev to 8800rpm doesnt mean it should.
    id say a 7age that gets revved to that regularly it wouldnt last very long
    HAHAH I LOVE BOOST LOOSING!!
  10. #30
    i disagree...i think its more of a case that no1 does it properly...everyone sees them as a "cheap" torque increase and dnt think it over...
    guys in NZ have been building them for awhile and quite successfully so it seems...
    quite interested in seeing how grantobius goes with his...
  1. 7ag 20V - which timing belt?
    By Grant #2 in forum Technical - Questions
    Last Post: 14th October 2012, 02:18 AM
  2. 7AG and compression ratios
    By Golden Circle in forum Technical - Questions
    Last Post: 28th May 2012, 06:36 PM
  3. Replies: 2
    Last Post: 13th November 2010, 06:30 PM
  4. 7AG(T)E
    By lo_rolla in forum Technical - Questions
    Last Post: 14th November 2006, 02:39 AM
