cant wait for the low down..............
l should have some b/t 7age true power figures in 2 weeks when its booked in to be tuned
Blacktop 7age reppin
BENT MECHANIX - Garage 20:
itll never get tuned grant
thanks for the drinks sat night pinky
06/07/2011
come on pat that aint the spirit, lol jrod is tuning is tuning so it proly will run but make 50hp less then his so he can beat me
why not go with a prober 4ag stroker kit, like a cyb one? they arnt that expensive when you compare to hi-comp pistons and rods +prep work for non stroker bottom end..
Dude!! your weak haha
go a stock 20v import motor (thats unmolested) and just put a microtech on it... ull have to spend a little bit but it'll be reliable and bust a decent skid...
where do you find info on them shaggy nuts?
NEAR MISS
type in your questions to the drift wikipedia, goes by delazy on here :p
i found consie a bare s14 sr20det with like 80k's for 2000 delivs... surely we could find a cheap decent 20v
I have a conversion that is pretty much bolt in and ready to go
AE111 Blacktop 20v motor. Roughly 60,000~km
Resealed
Toyota Coil packs
Adaptronic with tune for 20v
Loom to suit 20v and adaptronic, few wires need to be connected for it to run
Kaizen Garage Distributor Cover
70mm stacks, good size to run an airbox
RS-Chita 20v Water Kit. This makes it extremely simple to put into an excisting 4age equiped 86 or even a 4ac one. 16v radiator hoses can be used.
Running the 16v rwd water pump and thermostat setup
200mm 16v Flywheel
Heavy Duty Sesco Clutch (Same factory as excedy)
JDM T50 Gearbox with Slave/Fork etc
Engine brackets with Brand new Rubber/Insulator Mounts.
$3500
Now go through and find prices for all this stuff. You will find for a CLEAN BOLT-IN 20v that is very very cheap
