Results 1 to 4 of 4
Thread: 20V cam timing
    Juston
    Default 20V cam timing
    Can anyone tell me the stock cam timing for a silvertop? As in when inlet and exhaust valves open and close ATBC, BTDC, etc.
    I've tried to search but come up with nothing.
    Moderator Frak's Avatar
    Jamie
    Default 20v timing
    inlet open 0 deg TDC
    inlet closes 70deg ABDC
    When the vvt is switched on the cam timing is advanced 30 deg to;
    inlet open 30 deg BTDC
    inlet close 40 deg ABDC
    Ex opens 54 deg BBDC
    Ex closes 16 deg ATDC
    Hachiroku since 1994
    Juston
    Cheers for that.
    Juston
  1. 20 valve timing cover spacer (middle timing cover, alloy plate)
    By KE70Man in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 06:30 PM
  2. 20v cam timing
    By NIZLAH in forum Technical - Questions
    Last Post: 29th July 2009, 09:21 PM
  3. 4ac timing
    By sonsta in forum Technical - Questions
    Last Post: 2nd July 2009, 11:20 AM
  4. 20v timing
    By dr1ft-pig in forum Technical - Questions
    Last Post: 28th August 2007, 12:08 PM
  5. Timing
    By sinister086 in forum Technical - Questions
    Last Post: 18th December 2005, 12:38 AM
