As per title.
Already have the alternator bracket but if you also have the water pipe that attaches to the back of of the outlet that would be helpful as mine is currently seized to the corroded outlet I currently have. A decent rear water outlet would also be a bonus as I've had to cut the pipe down a lot due to corrosion.
And I'm also after a valve spring seat, the little cup washer that sits between the head and the valve spring. Lost one during my rebuild...
PM or reply here, cheers!
