What do pajeros run inside their drums? Id run that as the wheel cylinder size.
When i designed mine I chose parts that worked with the stock MC, so I chose Ra40 struts and fitted ae86 wheel cylinders in the drums on the F series and it all works perfectly with stock MC.
I dare say you are moving more fluid than a T series drum rear end would normally have pushed at it, considering the mc has the same piston travel but a larger piston diameter. Therefore the wheel cylinder you use will need to process a larger amount of fluid. I would assume the change to a 15/16 mc would need a change to a 15/16 wheel cylinder if the stock sizes are 13/16 and 13/16. If you used a 13/16th wheel cylinder you would probably find there was a tendency to lock the rear drums, which is fatal.
I found an amazing catalogue that lists a shot tonne of different brake parts and their hydraulic sizes. Ill see if I can attach it, Ive used it so many times.
File is too large, PM me and I can email it.
