The rubber grommets holding them slide towards the center and click out.
Might be a bit easier if ya spray some wd40 or similar to help
Sent from my SM-G935F using Tapatalk
I've done it before and now I feel so noob but does anyone have advice on unhooking these brake lines from the bracket?
Sent from my MI 5s using Tapatalk
Its easy if you push on both sides of the bean at the same time, if they are old and crispy you can snap them then they dont hold right. I just used needle nose pliers to contact both sides then tapped the pliers to pop them.
Yeah. Thanks everyone. Was just a bit of elbow grease.
