Results 1 to 8 of 8
Thread: 20v itb techno toy adapter 16v
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Default 20v itb techno toy adapter 16v
    Any experience installing this set up on the 16v
    My set up 12,5 Cr wiseco, 304 cams , old e6k tps reference, injectors yellow toyota 290 cc
    Engine power dives after 6,500
    Any idea
    Thanks
    Sent from my iPhone using Tapatalk
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Need more info, what have you already checked. Did you verify that you have enough throttle cable travel?
    DaveW
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Dave
    I will have to check several items and that its one of them
    I am running a very old e6k , tps reference,
    304 cams, 12,5 Cr, afr last run was 11,7
    I sent the injectors to clean( i bought thise ones in ebay yellow color , supposedly 290 cc, plead correct me)
    Soo yes , I will have a check on that
    Jun 2011
    james
    oxford
    general area
    England
    11.7 AFR is too rich and that amount of extra fuel will make a difference to the power.
    Aim for something around 12.8 at full throttle.
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    As mentioned the A/F ratio, but my guess is cam timing. I would verify BOTH cams. With 304* cams you should be just be coming up on the power band at 6,500 RPM. Either borrow or invest in a dial indicator and a degree wheel. [cam(s) probably advanced] After adjusting the cams, re-set timing. Davew7
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Yes, I will change the injectors, are too big
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Thanks , definitely right
    Do have a degree cam and a dial indicator
    I will degree this engine and I will check all the little details thats it’s needed
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Hi
    I did fix the problem
    Timing, I was using distributor fix ignition, using 32 degrees.
    Somehow at high RPM the time advance about 12 degrees.
    Found the issue and installed a electromotive 60-2 spark system
  1. (WA) Techno Toy Tuning RCA's - Like New
    By aaron in forum Car Parts For Sale
    Last Post: 5th April 2015, 03:12 PM
  2. Techno TRV. Full set! QLD
    By luke20 in forum Car Parts For Sale - Wheels
    Last Post: 17th November 2012, 03:37 PM
  3. Replies: 2
    Last Post: 11th July 2012, 09:08 PM
  4. Techno Toy Tuning
    By Jonny_G in forum General Topics (No Technical Questions)
    Last Post: 9th April 2008, 04:10 PM
  5. pure hot. ssr techno's
    By jono86 in forum Car Parts For Sale
    Last Post: 28th January 2008, 11:59 PM
