Results 1 to 2 of 2
Thread: Advice - 20v BT swap into ae85
    Jun 2021
    Tony
    Cromwell
    Cromwell
    New Zealand
    Default Advice - 20v BT swap into ae85
    Hey guys looking for some advice
    I've recently been trying to start my engine for the first time but am having problems getting it started. The obvious troubleshooting has been done, battery checked, wiring checked, grounds checked, vacuums checked, running evap with cannister new vacuums. I broke the vacuum valve on the map sensor vacuum line so am.using one off a 4afe that plugs directly into the block, but have thus running off the usual lines on the BT.
    Has sq dizzy relocation, starter motor, oil pump pressure up kit and water kit. Toda flywheel, extractors, cambelt. Standard ecu.
    Turns over and has spark but doesn't fire, just does a really low deep backfire kinda intermittently and Flames come out the exhaust header flange (haven't put the back half of the exhaust on yet). Like it's getting fuel and then firing after, timing issue?
    I'm using the two connectors off the 3au in the thermostat housing.
    Am hoping for some advice maybe change the sensors on the thermostat and the vacuum on the map? Or these don't matter so much?
    Video of trying to start her below
    https://drive.google.com/folderview?id=1dvBuM8KEzAoq_e1rdTF_5GVtMtVvcCHr
    The 20v will start with the map sensor disconnected, but will run terrible.
    Best bet is to put a timing light on it or if you don't have one, turn it to TDC and check to see where the dizzy cap should be on the lead which is heading to cyclinder 1.
    Do you know if the injectors are pulsing - a noid light will tell you this? Also hook up a check engine light if you are running the stock ecu.
  1. need some 20v engine advice!!
    By thooomas in forum Technical - Questions
    Last Post: 19th June 2014, 12:08 AM
  2. 4age 20v for sale or swap!
    By [-not-agn-] in forum Car Parts For Sale
    Last Post: 28th August 2013, 11:34 AM
  3. need some advice on installing 20v itbs on 16v 4age bigport
    By 2ftsim in forum Technical - Questions
    Last Post: 11th February 2013, 08:16 PM
  4. Any advice, blacktop 20v 7age wont rev past 6500rpm
    By JinxD in forum Technical - Questions
    Last Post: 20th January 2013, 07:07 PM
  5. can EASILY swap a st 20v for a bt 20v
    By dave2221 in forum Technical - Questions
    Last Post: 20th July 2009, 09:34 PM
Tags for this Thread
