Results 1 to 2 of 2
Thread: clutchs/flywheel 4ac -> 4age
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Question clutchs/flywheel 4ac -> 4age
    the clutch is rooted in my ae71 nd i'm gunna buy a new one
    was just wondering the differences between a 4ac flywheel and a 4age one.
    i know the 4ac is a six bout and 4age is 8
    the real question is if i buy a good (expencive) clutch for my 4ac will it bolt up to a 4age, as i will be converting it soon. or should i just buy a cheap shitty one till then?
    Mark
    Depends on which 4age you get.
    Ae92 Smallports have a 212mm flywheel. ae82 bigports have 200mm same as 4acs.
    So you can run your 200mm 4ac clutch on or even on the 212mm though that is dodgy.
    However I don't know what pressure a 4ac pressure plate exerts. it might be a lot less than the 4ag on.
    Isn't it only like $70 for a standard replacement for the 4ac anyway? Just get the stock part then buy the better one when you change motors.
    Im running an exedy standard replacement on my smallport and it hasn't slipped yet!!
  1. brissy>>>4ac bare motor with everything just not attached
    By phil-720 in forum Car Parts For Sale
    Last Post: 30th March 2011, 01:20 PM
  2. 4ac -> 4age gearbox issues
    By yes02t in forum Technical - Questions
    Last Post: 12th August 2008, 11:15 AM
  3. AE86 ADM Brakes, 4AGE Flywheel/Clutch, 4AC
    By HighLife in forum Car Parts For Sale
    Last Post: 22nd February 2007, 04:56 PM
  4. 4ac -> 4age engine swap
    Last Post: 15th February 2007, 11:02 PM
  5. 4AC -> 4AGE
    By xero in forum Technical - Questions
    Last Post: 21st July 2005, 05:24 PM
