The tech questions of late have been abysmal, to rectify this others and I
will be keeping a close eye on what is being posted. Will not even remotely
hesitate to delete something that is basically nothing more than a poorly
worded, structured etc topic.
Firstly, things such as general maintenance and other minor things can be found VERY readily on Google. If it shows you have not taken the time to find the information your thread will be removed.
Secondly, this site has already a very substantial amount of answers within these pages, all of which can be very easily found with a search.
Thirdly, if the following template is not used your post will be removed.
Name of topic - Model of part and problem.
for example;
- 20v silvertop, faulty spark
- t series diff, whining
- ke70 chassis, bent chassis, fixable?
Within the thread
CAR -
MOTOR -
USE -
PROBLEM/QUESTION -
OCCURS/STARTED WHEN -
for example
CAR - ke70
MOTOR - 3sgte
USE - drift/hill climbs/time attack/street
PROBLEM - not running properly
OCCURS/STARTED WHEN - I pulled the car to pieces
or
CAR - ae86 (jdm coupe)
MOTOR - 4age 16v
USE - drift
PROBLEM - clunking noise from diff (t series/trd 2 way)
OCCURS/STARTED WHEN - after last drift day, occurs when i turn sharply
at lowish speeds.
If it doesn't look like this, then don't expect your thread to be there, never mind an answer.
Beally
EDIT: also from here on there will a universal thread listing, all threads for certain topics have a set thread for them, to see the listing see
