Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 32
Thread: 4AGE MASTER BOOK a guide to all things 4AGE *cooling system update 18/8/2009*
  1. #21
    Jon
    Durack
    the whole book in english would be awesome LOL!
    can i have all pages?
  2. #22
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    Number 20 the 2 coolant sensors, can anyone tell me which is the one for the ecu and which is the one for the cold start as only one of mine is plugged in, one is green one is brown..
    cheers!
    Formerly known as grape_moosha
  3. #23
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Brown is cold start
    Green is ECU temp
  4. #24
    Alex
    Northfield
    ok thanks looks like il leave it unplugged( mines got the ecu one plugged in) and continue my search for why my bigport is slow
  5. #25
    Member Golden Circle's Avatar
    Oct 2011
    Clinton
    Hills District
    can someone clear the air for me please? what is going on on the back of the water pump? and what is that tube that gets stuck into it??
  6. #26
    Lawrence
    Wollongong
    That tube goes between the back of the pump and the top outlet.
    Its purpose to criculate water through the engine when the thermostat is closed.
    The pipe which goes off the back of the pump to the rear of the block is the heater bypass.
  7. #27
    Oct 2011
    Clinton
    Hills District
    thanks heaps goldberg. can you buy the tube anywhere? you're a proper sick ####, I'm just reading your 16v cooling guide now on rollaclub.
  8. #28
    Oct 2011
    Clinton
    Hills District
    just reading it now, Golberg if I'm running carbs on my 7a can I even take advantage of the throttle body cooling? and could just get away with using my 4AC rear water pipe?
  9. #29
    Lawrence
    Wollongong
    Indeed, use the 4AC pipe.
    Depending on if you have a knock sensor you may be able to just bolt it straight on.
  10. #30
    Member High-Rolla's Avatar
    Feb 2013
    Nathan
    is the book downloadable (english) or buy? and if so where !
  1. RWD 4age cooling system.
    By aussie freestylers in forum Cars or Parts Wanted
    Last Post: 14th April 2010, 12:10 PM
  2. Golberg’s 4AGE 16V Cooling Guide
    By Golberg in forum Technical - Articles
    Last Post: 24th June 2008, 10:37 PM
  3. 4age water/cooling system.
    By HiLtOn in forum Technical - Questions
    Last Post: 2nd April 2007, 08:01 PM
  4. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Technical - Articles
    Last Post: 26th March 2007, 01:00 AM
  5. 4age Cooling System
    By Jazz9 in forum Technical - Questions
    Last Post: 9th March 2007, 05:45 PM
