Page 11 of 41 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 101 to 110 of 401
Thread: steroidchickens levin coupe
  1. #101
    Veteran Kid Karola's Avatar
    Karl
    S.A.
    Austria
    yeah 3SGE's will do that, tall motors. with the older turbo version the manifold would actually sit even higher like thru the bonnet .
  2. #102
    Ow dear as suspected..
  3. #103
    Veteran driftke70's Avatar
    Ryan
    Buderim
    and the newer ones,
    my beams sumps a little lower, and i a wee bit further back, my starter has about 30mm clearance, looks like bit of a tight fit, if you can be bothered just go in from the other side and tig a little mount and brace, cut a little box out the tunnel.
    wheelfriends.wordpress.com
  4. #104
    Brad
    Central coast
    i dont want it to be any lower. idealy it would be better lower. but already the sump is the lowest point of the car. one ripple strip and it will be gone.
  5. #105
    Can you modify the sump and pickup a little. obviously its not ideal. or make a nice bash plate.
  6. #106
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    i PM'd you the pics of my setup
    sump will be fine, mine was 25mm below x member, id recommend a bash plate though if your going to see ripple strips
    MY JZX83 (clicky)
  7. #107
    Jul 2009
    Daniel
    Morisset
    nice work man now to sort out what parts i want from your previous motor.
  8. #108
    User fantapants's Avatar
    Pat
    and take the hat off its not high really.... yeah its higher than a 4 a... but its not awful
    06/07/2011
  9. #109
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    your using a 4y bellhousing ? does the clutch fork clear the floor at full extenstion ? im thinking bout changing to a 4y one to get my starter and clutch slave away from the exhaust altho it hasnt been a problem yet
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  10. #110
    Brad
    Central coast
    yeah. clutch fork clears by a mile. well about 60mm. just had to give fuel lines a bit of a tweak. its 3y i think.
    you running 2s bell?
  1. steroidchickens d22
    By steroidchickens in forum Other Rides
    Last Post: 11th September 2010, 02:50 PM
  2. Levin Coupe
    By sundee in forum Cars or Parts Wanted
    Last Post: 18th May 2010, 11:36 AM
  3. My Levin Coupe
    By Monster in forum Cars for Sale (Toyota Only)
    Last Post: 13th September 2008, 09:29 PM
  4. levin coupe
    By 4AGE - 86 in forum Cars for Sale (Toyota Only)
    Last Post: 24th July 2008, 09:49 PM
  5. Levin Coupe
    Last Post: 15th June 2008, 03:34 AM
