That's one shit sentence.
Have a look here:
You should be able to find a diagram for the carby on a 4ac. It will point out the idle adjustment screw and give you instructions.
Chris.
Wondering how u adjust the idle one a 4ac sprinter its idle when warm at about 1300rpm and the needle has not been lifted so i am not sure wear to lower it ?
Have a look here:
Chris.
There will be a throttle return screw which needs adjusting. Take off the air filter and housing and look at the back of the carby facing the firewall. You should see the throttle linkages there. Play around with it and you will quickly find what you need to do to adjust the throttle return screw.
thanks will do that tomorrow
learn how to spell vtaz
If In Doubt, Drift Her Out.
Fixed.
He is Japanese and translated it to English.
"That of which the idle is raw and high above the top, bringing down to 1000rpm. Bid with confidence."
